psckrat Posted February 25, 2004 Posted February 25, 2004 Hi; Just took my new (92) SC400 out in the snow. When I raised the trunk lid with about an inch of new snow, not only was it diificult to raise, but it would not stay up. There are no struts in the trunk to assist with raising. Question? Is the an 'easy lift' out there, what about remote opening Thanks Bob
JDOwen2 Posted February 25, 2004 Posted February 25, 2004 If you pull out the rear panel in the trunk you should see a strut cartridge on each side. You almost have to climb into the trunk to see them. Considering they are 10 years old, it's time to replace them. You can find them on Ebay or from one of the Forum supporters. I've never investigated remote trunk access. Might be out there somewhere. Enjoy the ride and don't forget to wave.
bean_8044 Posted February 26, 2004 Posted February 26, 2004 You could replace a strut with a linear actuator, but thats going to be about $300
KY3TS Posted February 26, 2004 Posted February 26, 2004 go to autozone and order them for about $25.00 per "trunk lift" as they are called-- the part # should be 95270--this is for a 1995 sc400 but the lifts should be the same. have autozone check that. good luck
psckrat Posted February 26, 2004 Author Posted February 26, 2004 Thanks to all responders. Went to AZ yesterday ordered lift's about $25.00 per unit. Looking forward to installing. Btw got a 'universal remote trunk opener'. Be interesting to see what is involved. Thanks again
