StreetLegal-ish3 Posted July 17, 2011 Posted July 17, 2011 I have a 2000 GS400. I turned me car on yesterday and everything was normal, but my dash stayed dark, and the gauges never came on. I tried messing with the battery and changed the gauge fuse, but nothing changed. Anybody have any other ways to fix this type of problem?
cduluk Posted July 17, 2011 Posted July 17, 2011 Are any other lights on the dash on? ie P-R-N-D-4-3-L, or the seatbelt light, etc? And do the needles move like they're supposed to?
DEATH_AWAITS_YOU Posted July 18, 2011 Posted July 18, 2011 I have a 2000 GS400. I turned me car on yesterday and everything was normal, but my dash stayed dark, and the gauges never came on. I tried messing with the battery and changed the gauge fuse, but nothing changed. Anybody have any other ways to fix this type of problem? Contact your dealer for a replacement instrument cluster. Not very common, but I've seen it a few times before on that same model (GS300/400) He will need to know your actual mileage so the replacement unit can be programmed to the same mileage.
cduluk Posted July 18, 2011 Posted July 18, 2011 Uhh, no. Do not buy a cluster from the dealer. A new cluster from the dealer costs almost as much as a used GS. First you need to determine if the cluster is faulty, or if it's something external. If you do end up needing a cluster, grab one off of ebay. Depending on what the issue is within the cluster, you may be able to keep your memory board for the mileage.
StreetLegal-ish3 Posted July 23, 2011 Author Posted July 23, 2011 None of the needles work... only lights that come on are check engine light, high beam light, but it's very dim.
StreetLegal-ish3 Posted July 23, 2011 Author Posted July 23, 2011 CORRECTION: When I turn the car to the ON position, all the lights on the lower part of the dash come on. (seat belt, oil, engine lights etc.) But the dash never lights up, or needles done move. Also, can't see mileage, or park/gears
StreetLegal-ish3 Posted July 23, 2011 Author Posted July 23, 2011 JUST FIXED THE PROBLEM: I took the battery apart and cleaned the post with a wire brush, tightened it up, and my dash came back on! Thanks for everyones help!
cduluk Posted August 1, 2011 Posted August 1, 2011 I was gonna say... sounds like a low battery issue. When the car's battery gets low, the car cuts power to all nonessential systems such as the gauges. <_<
