Jackster Posted July 15, 2011 Posted July 15, 2011 I was wondering if anyone knew how to install/replace the mirror ECU that tends to go bad in these cars (95 SC300). I have the new one, plugged it up and it worked but I'm having the damnedest time getting the old one out. I have taken the dash apart as far as I know how I can get to the bottom screw but there is another one up top that I just can't get to no matter what I do. Any suggestions? If you know of any dash diagrams that would help too. Thanks so much guys.
DEATH_AWAITS_YOU Posted July 15, 2011 Posted July 15, 2011 I was wondering if anyone knew how to install/replace the mirror ECU that tends to go bad in these cars (95 SC300). I have the new one, plugged it up and it worked but I'm having the damnedest time getting the old one out. I have taken the dash apart as far as I know how I can get to the bottom screw but there is another one up top that I just can't get to no matter what I do. Any suggestions? If you know of any dash diagrams that would help too. Thanks so much guys. I haven't done one in a long time, but if I'm not mistaken(and I never am), the way to get to it is from behind the radio. Using 1/4" extension and swivel socket. Not necessary to remove it though. Just use some double sided tape or zip ties to hold it in place so it doesn't rattle.
Jackster Posted July 18, 2011 Author Posted July 18, 2011 Thanks for the advice. Yeah this car is built pretty tight and solid.
