Darvish11 Posted June 30, 2011 Share Posted June 30, 2011 Hi Everyone, I bought my 2004 ES330 from a Lexus dealer about two months ago and am very happy with the car.Except that I can not program the Homelink garage door opener.I have read and watched the video instructions on HomeLink site,Youtube, Lexus Manual,My garage door site (Genie),different blogs about this .I have tried different senarios such as having the engine running while trying to program or having it turned off.Parked my car outside the garage or inside the garage to see if it makes any difference.Tried to program different buttons incase one might be bad. Nothing has worked.It seems that I am able to do half of the programing where I sync the house opener with the Homelink but then I can not finish with the rolling code of the garage door opener. I am frustrated and can not think of anything else to do. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted June 30, 2011 Share Posted June 30, 2011 And you are following the instructions in your owners manual and any that are specific to your garage door opener model?: From your owners manual: If your device is “Rolling Code” equipped, it is necessary to follow steps 1 through 4 under the heading “Programming the HomeLink” before proceeding with the steps listed below. 1. Locate the “training” button on the ceiling mounted garage door opener motor. The exact location and color of the button may vary by brand of garage door opener. Refer to the owner’s guide supplied by the garage door opener manufacturer for the location of this “training” button. 2. Press the “training” button on the ceiling mounted garage door opener motor. 3. Press and release the vehicle’s programmed HomeLink button twice. The garage door may open. If the door does open, the programming process is complete. If the door does not open, press and release the button a third time. This third press and release will complete the programming process by opening the garage door. The ceiling mounted garage door opener motor should now recognize the HomeLink unit and be able activate the garage door up/down. 4. Repeat steps 1 through 3 for each remaining HomeLink button to program another rolling code system. I suppose it is possible that your garage door opener is not compatible. If it is, most garage door openers can be fitted with new HomeLink compatible receivers without replacing the entire garage door opener. It has sometimes taken me several tries to program a HomeLink button - timing is everything. If all else fails, follow the instructions in the attached image. :whistles: Quote Link to comment Share on other sites More sharing options...
sump Posted July 1, 2011 Share Posted July 1, 2011 I agree. follow the instructions....It took me like 10 minutes to get my opener to work....I still dislike this model year. Quote Link to comment Share on other sites More sharing options...
MrScott Posted January 30, 2013 Share Posted January 30, 2013 I am curious if you have a new home and/or garage door opener? If yes, is it Craftsman, Chamberlain, or Liftmaster? Quote Link to comment Share on other sites More sharing options...
91ES300 Posted September 3, 2013 Share Posted September 3, 2013 I feel compelled to comment on this - This took forever to do for me on my new to me ES300 yesterday. I have to recruit my wife to help. I have a liftmaster rolling code opener and it seemed as though, 1st I had to do the regular part with the opener remote and then following the steps and do the rolling code with the opener itself attached to the ceiling. Hope this helps! Also, only 1 of my buttons would program for some reason. Quote Link to comment Share on other sites More sharing options...
