Phone Charging
Is it possible to charge my phone or other accessory with the ignition and ACC off?
Yes, if you install an accessory power port or charging cradle that is attached to an always hot power source. My phone cradle/charger is attached to the ignition switch and can charge my phone with the ignition switch off and the key removed. But I don't have a need to do that.
What problem are you trying to solve? Maybe there is another way?
