spidzee Posted May 31, 2011 Posted May 31, 2011 I've seen ads or SC300 hp boost chips. Are they worth it? Do they really increase the hp?And save gas? And if anyone know how to eliminate condensation inside my headlamp-I would appreciate some help. Can you remove the lens? thanks jj
grnsc40095 Posted June 3, 2011 Posted June 3, 2011 HP boost chip waste of money, another simple option is a BFI. http://planetsoarer.com/indexfull.html#BFI As far as your head light, sounds like a seal problem. Here are a few DIY http://www.clublexus.com/forums/sc-400-300/568998-first-attempt-diy-headlight-cleanup-fail.html http://www.clublexus.com/forums/sc-400-300/566396-easy-fix-for-condensation-in-headlamps.html http://web.ace.net.au/soarer/headlight_cleaning.html[/size
