Blue Screen And 3 Dome Lights Out!
kim812251
Today my blue screen, 3 dome lights, radio, cd/radio player, and preset seats went out. Everything else is working fine. Please help me out with any suggestion or comments would be great. And one more question, will this affect my car while i drive it. Thanks
the is a 10a dome fuse in the fuse box...it does fire the instruments also...as for checking fuses you pull it and look through it. There should be a continuous path from from one spade to the other spade. for reference look at a known good fuse and compare. A voltmeter makes the job much easier by measureing resistance through the fuse it should measure 0 ohms when good. However the fuses are made for visual inspection.
