Hello, I have a 2004 LS430, the check VSC warning light is on and when I try to re-set it. It says mileage re-set and then back to check VSC! How do you re-set the mileage?
Wouldn't you simply disconnect the negative battery terminal for a few seconds, then reconnect?
I tried that, It didn't work! Still the same!
Hello, I just tried that link you told me about. jumping the two connectors. And it worked!!! What could have caused the check VSC warning and mileage re-set? I have an 04 LS430 Ultra with 59000 miles. Thanks for your help!
Many issues, usually unrelated to VSC, can cause the VSC warning -- you could see if there are any stored problem codes or wait until the real problem becomes severe enough to become obvious.
  • 2 years later...
