Ruud Posted January 31, 2011 Share Posted January 31, 2011 Hi everyone, My LS (1994) has hardly any warm air coming from the vents and smells like an Indian Takeout when it is warmed up :) I have been told this could be caused by the heater core/matrix being on it's way out. Has anyone attempted to replace the heater core? Quote Link to comment Share on other sites More sharing options...
yotoy82 Posted February 1, 2011 Share Posted February 1, 2011 I'm not sure about the core but you could get a charcoal cabin filter, they really help stop smells from coming inside the car! Quote Link to comment Share on other sites More sharing options...
Ruud Posted February 1, 2011 Author Share Posted February 1, 2011 I'm not sure about the core but you could get a charcoal cabin filter, they really help stop smells from coming inside the car! lol..the smell is not coming from outside. Quote Link to comment Share on other sites More sharing options...
steve2006 Posted February 1, 2011 Share Posted February 1, 2011 I'm not sure about the core but you could get a charcoal cabin filter, they really help stop smells from coming inside the car! lol..the smell is not coming from outside. Ah but the A/C filter could be clogged causing the poor air flow and the smell Quote Link to comment Share on other sites More sharing options...
Ruud Posted February 1, 2011 Author Share Posted February 1, 2011 I'm not sure about the core but you could get a charcoal cabin filter, they really help stop smells from coming inside the car! lol..the smell is not coming from outside. Ah but the A/C filter could be clogged causing the poor air flow and the smell I don't have poor air flow though. Just to be safe, where is this A/C filer located? Is it the pollen filter? Quote Link to comment Share on other sites More sharing options...
yotoy82 Posted February 2, 2011 Share Posted February 2, 2011 I'm not sure about the core but you could get a charcoal cabin filter, they really help stop smells from coming inside the car! lol..the smell is not coming from outside. Ah but the A/C filter could be clogged causing the poor air flow and the smell I don't have poor air flow though. Just to be safe, where is this A/C filer located? Is it the pollen filter? A/C filter, ie Cabin Filter, ie Pollen Filter, is the filter located behind the glove compartment. Quote Link to comment Share on other sites More sharing options...
steve2006 Posted February 2, 2011 Share Posted February 2, 2011 Lay in the footwell and look up behind the glovebox,you should see a black plastic box with 2 wing-nuts,unscrew them and the bottom panel will come off exposing the filter(s). I actually washed mine in soapy water,rinsed,allowed to dry,sprayed with air freshener and refitted.They are probably $20.00 to you guys but cost over $60.00 in the UK Quote Link to comment Share on other sites More sharing options...
Ruud Posted February 3, 2011 Author Share Posted February 3, 2011 Lay in the footwell and look up behind the glovebox,you should see a black plastic box with 2 wing-nuts,unscrew them and the bottom panel will come off exposing the filter(s). I actually washed mine in soapy water,rinsed,allowed to dry,sprayed with air freshener and refitted.They are probably $20.00 to you guys but cost over $60.00 in the UK ah, pollen filter was changed earlier this year. Quote Link to comment Share on other sites More sharing options...
Old13NewLs Posted February 4, 2011 Share Posted February 4, 2011 Is it a methane type smell (natural gas ie; !Removed!...)? And does it come and go? Mine does this periodically. I've been told it could be one of the cats going bad. Quote Link to comment Share on other sites More sharing options...
Ruud Posted February 4, 2011 Author Share Posted February 4, 2011 Is it a methane type smell (natural gas ie; !Removed!...)? And does it come and go? Mine does this periodically. I've been told it could be one of the cats going bad. No, it's not methane. The smell is really only there in the morning, when she is warmed up. The rest of the day is fine. Iknow the smell of a bad cat., that's more like a rotten egg smell :) Quote Link to comment Share on other sites More sharing options...
steve2006 Posted February 4, 2011 Share Posted February 4, 2011 Have you considered getting one of those AC cleaner aerosols,the one where you put the AC on max cold,set the thing off behind the front passenger seat(I use the rear part of the transmission tunnel) then leave until its done it's job. I bought a few from Aldi a while ago but they are readily available elsewhere. Quote Link to comment Share on other sites More sharing options...
Ruud Posted February 4, 2011 Author Share Posted February 4, 2011 Have you considered getting one of those AC cleaner aerosols,the one where you put the AC on max cold,set the thing off behind the front passenger seat(I use the rear part of the transmission tunnel) then leave until its done it's job. I bought a few from Aldi a while ago but they are readily available elsewhere. umm..I have never even heard of them..lol How can they clean a closed system from behind the passenger seat? Quote Link to comment Share on other sites More sharing options...
steve2006 Posted February 4, 2011 Share Posted February 4, 2011 Like I said start the car,open all the vents,make sure the air is set to recirculate,set the AC to max cold,set the thing off in the back of the car,leave it 10 minutes for the can to empty and circulate around the system then leave the doors open to vent the excess. http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_224996_langId_-1_categoryId_165632 Quote Link to comment Share on other sites More sharing options...
Ruud Posted February 4, 2011 Author Share Posted February 4, 2011 Like I said start the car,open all the vents,make sure the air is set to recirculate,set the AC to max cold,set the thing off in the back of the car,leave it 10 minutes for the can to empty and circulate around the system then leave the doors open to vent the excess. http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_224996_langId_-1_categoryId_165632 Thanks Steve, I'll give it a try Quote Link to comment Share on other sites More sharing options...
McSwine Posted February 7, 2011 Share Posted February 7, 2011 I see you have the extremely rare and highly desirable "Red Curry" limited edition. (sorry...) Quote Link to comment Share on other sites More sharing options...
Ruud Posted February 7, 2011 Author Share Posted February 7, 2011 I see you have the extremely rare and highly desirable "Red Curry" limited edition. (sorry...) Indeed I do :) I have found out that these are quite the collector's item these days. Lexus LS400 RC Limited Edition :) Quote Link to comment Share on other sites More sharing options...
Ruud Posted February 13, 2011 Author Share Posted February 13, 2011 the guy in the below link has exactly the same issue http://www.lextreme.com/forums/showthread.php?t=9020 Anyone here knows what a vapor trap is? Quote Link to comment Share on other sites More sharing options...
kuziwk Posted February 13, 2011 Share Posted February 13, 2011 Mine use to smell like bad B.O. from the airvents whenever i washed it. Since than ive cleaned the carpets, used air fresheners, scrubbed the leather with vim (yes they were very grimy and black), cleaned all the cigarette ash out of the door panels. Eventually the car stopped smelling, and now smells like leather due to the cleaner/conditioner i use. Quote Link to comment Share on other sites More sharing options...
magic Posted February 15, 2011 Share Posted February 15, 2011 What kind of smell? Is it Tandoori or Tikka? Quote Link to comment Share on other sites More sharing options...
Ruud Posted February 15, 2011 Author Share Posted February 15, 2011 Does anyone actually reads the posts, or just the topic title? Quote Link to comment Share on other sites More sharing options...
SRK Posted February 16, 2011 Share Posted February 16, 2011 Well it was a great topic title! As to the question, if your heater core was leaking you'd have a fine scum of coolant on the inside of the windshield. It would be difficult to remove. If that isn't present, then more than likely you have some sort of growth occurring in the heater box/evaporator box itself. There are biocides on the market designed to be fogged into the air intake for the HVAC system, that will kill whatever is growing. It's also possible that something has already died in there, but I doubt it. Smelly AC is a concern in many climates, Canada included. Once cured the best practice is to shut off the AC a few miles from home, run the fan up to full speed, and dry the evaporator core so that no moisture is present, eliminating the "growth medium" for various types of molds and other buggly-duds. Quote Link to comment Share on other sites More sharing options...
Ruud Posted February 16, 2011 Author Share Posted February 16, 2011 Well it was a great topic title! As to the question, if your heater core was leaking you'd have a fine scum of coolant on the inside of the windshield. It would be difficult to remove. If that isn't present, then more than likely you have some sort of growth occurring in the heater box/evaporator box itself. There are biocides on the market designed to be fogged into the air intake for the HVAC system, that will kill whatever is growing. It's also possible that something has already died in there, but I doubt it. Smelly AC is a concern in many climates, Canada included. Once cured the best practice is to shut off the AC a few miles from home, run the fan up to full speed, and dry the evaporator core so that no moisture is present, eliminating the "growth medium" for various types of molds and other buggly-duds. Thank you for your reply. The problem is that the smell is there when the car starts to heat up with the A/C off. I have used the 'fogged' a/c cleaner, but that did not make any difference. I am pretty sure it is coolant I smell. I get the same smell when coolant drips on the hot exhaust. I do not have any coolant scum on my windshield though. Quote Link to comment Share on other sites More sharing options...
