Zdeno Posted February 18, 2004 Share Posted February 18, 2004 Hi guy, I just thinking that I will change the spark plugs to my 1991 LS 400 167K and don´t know if I need to change cables too. So I´d like to ask you how often the wires need to be change. In my repare manual I found they recommending this 2 types of spurk plugs ND PK20R11 and NGK BKR6EP11 so I found the first one on web for good price I think. http://www.drivewire.com/OEMPartDetail/MYR...ND_PK20R11.html Please some info about wires. Thank you !!! Quote Link to comment Share on other sites More sharing options...
jzz30 Posted February 18, 2004 Share Posted February 18, 2004 these wires that come with the car look like they will last an easy 200k miles but i changed mine anyway at 100k which seems to be the normal Quote Link to comment Share on other sites More sharing options...
UCF3 Posted February 18, 2004 Share Posted February 18, 2004 you really don't have to swap the cables out. JUst make sure they are clean and leak-free. Some of us have replaced the cables because we wanted to get better performance from the cables, but you don't have to, unless there is something wrong with them. Quote Link to comment Share on other sites More sharing options...
VMF Posted February 18, 2004 Share Posted February 18, 2004 i changed whole ingnition setup at 120k denso rotors 7.5$x2 denso rotor caps11$x2 denso spark plugs IK20 80$ and denso cables 100$ Quote Link to comment Share on other sites More sharing options...
Zdeno Posted February 18, 2004 Author Share Posted February 18, 2004 Thank you very much guys !! Ok I´ll change just the spark plugs because I was thinking about the light vibration when I put the stick shift To R or D position, but when it is on P or N I don´t feel any vybration, tingle of my car. I was thinking that it can be trany or motor mounts or the bad spark plugs what do you think ? Quote Link to comment Share on other sites More sharing options...
VMF Posted February 18, 2004 Share Posted February 18, 2004 change wires as well, its recommended to change them once in a while. sometimes they are a cause for the weak spark. its only 100$ for the oem toyota part so i think you should do it Quote Link to comment Share on other sites More sharing options...
Zdeno Posted February 19, 2004 Author Share Posted February 19, 2004 Thank you I will change the cables too. And do you think that the vibration what I wrote can be effect from bad spark ?? Quote Link to comment Share on other sites More sharing options...
VMF Posted February 19, 2004 Share Posted February 19, 2004 you never know....everything is possible. my spark plus were so burned that when i did a tune up even the sound of the engine changed:) Quote Link to comment Share on other sites More sharing options...
thewzdoc Posted February 28, 2004 Share Posted February 28, 2004 SON OF A !!!!!! THe last spark plug is stuck...fast. I was able to turn it out about 2 turns but now it is totally stuck.... :chairshot: I'm going to buy some PB Blaster to see if the catalyst will break the bond......I hope to god it's not cross threaded.... Quote Link to comment Share on other sites More sharing options...
