I have a '07 IS250 with wood trim. I bought it used, and the previous owner was not terribly careful with the center console trim. It has several fine scratches. Is there an easy way to buff these out? What do you guys recommend?
I don't know if I would mess with it you make it worse. Try to PM SW...he may know of something. Here is his contact info http://us.lexusownersclub.com/forums/index.php?showuser=564
:cheers:
I'd try a plastic polish like Novus, Plexus, or Meguiars PlastX...
SEE! :cheers:
If they're deep enough to feel with your fingernail you can try wet-sanding the entire panel with 2000 grit sandpaper and machine polishing with a rubbing compound. The clear on the wood panels is an acrylic, so any polish will work.
Just don't wetsand unless you've removed the panels from the car and have a machine to polish with. NEVER try to do it by hand as it'll take too much time. <_<
