eodguy2 Posted January 4, 2011 Share Posted January 4, 2011 Started getting a burnt oil smell that is fairly strong inside passenger compartment. Had oil change about 3 weeks ago and was informed that may have smell for bit due to how design is and getting oil spill etc. really noticing this after being on interstate for about 20 mins. Only had car for about 3d months and never noticed before. No visible oil leaks around manifold or on ground, any ideas???? Quote Link to comment Share on other sites More sharing options...
pberku Posted January 4, 2011 Share Posted January 4, 2011 Started getting a burnt oil smell that is fairly strong inside passenger compartment. Had oil change about 3 weeks ago and was informed that may have smell for bit due to how design is and getting oil spill etc. really noticing this after being on interstate for about 20 mins. Only had car for about 3d months and never noticed before. No visible oil leaks around manifold or on ground, any ideas???? Check the area around the Oil filter for any evidence of spilled oil, resulting from the oil change. If its dry than you need to look further. Could also be the valve cover(s). Make sure that you identify the cause, and that you have enough oil, Quote Link to comment Share on other sites More sharing options...
eodguy2 Posted January 20, 2011 Author Share Posted January 20, 2011 Well, looks like I have a very small leak on rear main seal. Wii just live with it as cost of repair too much for value of car. At least its not marking itself on ground yet. Quote Link to comment Share on other sites More sharing options...
dcfish Posted January 20, 2011 Share Posted January 20, 2011 Seeping is different than leaking, If there are no spots on the ground, No problem. It is common that gaskets meet ther saturation points.B) Quote Link to comment Share on other sites More sharing options...
eodguy2 Posted January 21, 2011 Author Share Posted January 21, 2011 Dcfish, thanks, just have to put up with burnt oil smell Quote Link to comment Share on other sites More sharing options...
