Spiky Posted December 27, 2010 Share Posted December 27, 2010 First post. Just acquired an RX300. Did a search, most topics just discuss how to replace the antenna. My antenna only goes up about a foot, or one section of the mast. Not even to the top of the vehicle. I'm assuming that's not normal. Radio reception is actually fine, it's not an issue from that standpoint. It does retract all the way. Do you think I should mess with it? Are there any "lesser" reasons this might occur? (lesser than mast replacement) It does not keep running the antenna motor, just stops as if this was normal. Thanks. Quote Link to comment Share on other sites More sharing options...
tofu Posted December 28, 2010 Share Posted December 28, 2010 That is wierd, it usually makes some noises if it doesn't extend or retract all the way. If it don't make any noise and radio working fine than I wouldn't touch it at all. But if you decide to get it replaced you can buy them online. I just replaced mine a month ago and it's not that easy... Good luck.. Quote Link to comment Share on other sites More sharing options...
Coney05 Posted December 28, 2010 Share Posted December 28, 2010 Brroken mast cable i would guess Quote Link to comment Share on other sites More sharing options...
fernandolpa Posted December 29, 2010 Share Posted December 29, 2010 You have to change the mast antenna. Buy one on ebay and do thereplacement. It is not easy, lets say 6 to 10. I did that and problem solved. Quote Link to comment Share on other sites More sharing options...
Spiky Posted January 3, 2011 Author Share Posted January 3, 2011 That is wierd, it usually makes some noises if it doesn't extend or retract all the way. If it don't make any noise and radio working fine than I wouldn't touch it at all. But if you decide to get it replaced you can buy them online. I just replaced mine a month ago and it's not that easy... Good luck.. Yeah, my GMC van would just keep running the antenna motor for several seconds, even if it couldn't move the mast due to damage or ice. Maybe I'm just missing the noise somehow. Thanks for the comments. Quote Link to comment Share on other sites More sharing options...
