Just posted this the other day, and now I can't find it, so sorry for the repeat if it is posted elsewhere.
I have a 2011 ES350 with 215/55 17 tires.
Those are the only size tires the car can come with.
I would like to go with a bigger tire to improve handling.
To get the same diameter, I would need a 235/50 17, or a 235/45 18.
Please let me know if going from the 215 stock tire to the 235 will fit properly on the ES350.
I wouldn't think it would be a problem, but I am not sure sonce the factory does not offer a tire size option.
Thanks all.
  • Like 2
After speaking with some tire retailers..it sounds like you can safely go up one size from 215 to 225 (only a 10mm increase in width)
so to replace the stock 215/55-17 the 3 choices would be:
225/50-17
225/45-18 (need to upgrade the wheels)
225/40-19 (need to upgrade the wheels)
all 3 options have virtually the same diameter as the original, so the speedometer will be almost perfect, but performance would be improved with the any of the 3, with the larger wheels providing the biggest performance benefit
Please let me know if anyone has upgraded the tires on their es350..curious as to the handling improvement with the various upgrades
thanks
  • 3 weeks later...
  • 4 years later...
I am running 18x8 40 offset fronts IS 350 wheels on my es350 on 225/45/18 with no problems .... but would like to go to a 18x8 35 offset and 245 /45/18 but cannot find any info ...there is a post with a guy running 20 s on a 245 but not all specs are there he said no problems .I want to keep some of the ride comfort but do want the 18s . .any input appreciated.
I changed the tires on my ES330 to 225/60-16 car came with either 205mm or 215mm, can't remember. On the LS400 I had I changed the factory tires (205/65-15) to 225/60-15 without issues. As long as the tire is the same height, you will be okay. Tire Rack has comparision charts.
So now I am running a 245/45/18 18x8 rim 35 offset on my 07 es350 no problems. You can use the tire calculater on line to see the difference with the tires both stock and what you want to .l went from stock 215/55/17 to a 225/45/18 now to the wider 245/45/18 and just a hair taller with no problems and no modefications to car .The ride is even smoother. Hope that helps.
  • 1 year later...
i have a 2010 Es 350 .i recently bought 235/55/R17 tires pls advise if its safe. and the disadvantage and also can 5 liters of oil be enough for oil change?.
Tires are okay, seems about the standard size for that year. The 3.3L engine took 5qts, not so sure on the 3.5L.
