dcfish Posted February 16, 2004 Share Posted February 16, 2004 Has anybody used one of those multiwire negative ground assemblies that connect from the negative terminal of the battery then multiple wires are attached to various components in the engine bay ? Any positive results from the use of these ? any info will be greatly appreciated . thanx Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 17, 2004 Share Posted February 17, 2004 Yes i upgraded mine but i made my own wires to be exact and used new battery terminals. I replaced the starter and main battery ground wire . Car now runs stronger and stars faster than before. Quote Link to comment Share on other sites More sharing options...
dcfish Posted February 20, 2004 Author Share Posted February 20, 2004 what type of new battery terminals did you use ? and what gauge wire ? all copper ? what do you think about a ground wire to the head for spark ? thanx Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 20, 2004 Share Posted February 20, 2004 I used phoneix gold wires and terminals. I just followed the original wires cut them out and replaced with 4 gauge wire. I didn't want to add more grounds as that can cause a ground loop noise and interferance. Quote Link to comment Share on other sites More sharing options...
