AlmightyLexus Posted February 15, 2004 Share Posted February 15, 2004 wassup fellas...after having my 91 Lex LS400 sit up for, i'll say, four day it blows out a puff of smoke? what do you all think the problem is? also, what is valve clatter? Quote Link to comment Share on other sites More sharing options...
prix Posted February 15, 2004 Share Posted February 15, 2004 The web has a lot of info about what different colors of exhaust smoke can mean (blue/black v. white, etc.). Do a search and do some reading. Persistant white smoke (they say) is a 'classic' symptom of head gasket problems, but can also mean other things. If the smoke is coupled with valve clatter, maybe fuel injection timing is off? What I try to do is read up as much as possible, so that even though I still need to consult with a mechanic, I'll have a better understanding of the issues and can make informed decisions when authorizing repairs. You will need a diagnosis from a trained mechanic! If the smoke is persistent, don't put off remedying the situation!! Quote Link to comment Share on other sites More sharing options...
prix Posted February 15, 2004 Share Posted February 15, 2004 Also, if it's just a puff of smoke at start-up, that could be normal condensation and nothing to worry about. But if it 'lasts' then engine coolant could be leaking into the engine, etc...and you would need to have that checked out. Quote Link to comment Share on other sites More sharing options...
Steve Posted February 15, 2004 Share Posted February 15, 2004 valve stem seals could be a bit leaky... if so then not really much to worry about at the moment... not unusual for old cars to have this. Quote Link to comment Share on other sites More sharing options...
AlmightyLexus Posted February 15, 2004 Author Share Posted February 15, 2004 thanks a lot guys....and no it doesn't last while driving just when starting the car up after four days or so...i'll take the advice and take it to a trained mechanic Quote Link to comment Share on other sites More sharing options...
VMF Posted February 15, 2004 Share Posted February 15, 2004 check your coolant level on a regular basis and smell the cloud, how does it smelll? Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted February 15, 2004 Share Posted February 15, 2004 Probably the valve seals. No big deal for now, unless it gets really bad. Quote Link to comment Share on other sites More sharing options...
JETPILOT Posted February 19, 2004 Share Posted February 19, 2004 wassup fellas...after having my 91 Lex LS400 sit up for, i'll say, four day it blows out a puff of smoke? what do you all think the problem is? also, what is valve clatter? I'll bet your power steering fluid is disappearing too. If so the smoke is the PS fluid being sucked from the pump. Search the forum for a fix. I just disconnected and plugged the vacuum line from the pump. Quote Link to comment Share on other sites More sharing options...
99lsguy Posted February 20, 2004 Share Posted February 20, 2004 I'll bet your power steering fluid is disappearing too. If so the smoke is the PS fluid being sucked from the pump. Search the forum for a fix. I just disconnected and plugged the vacuum line from the pump. I agree with you Jetpilot :D That's a classic PS pressure valve malfunction.... Quote Link to comment Share on other sites More sharing options...
