born2ron Posted February 14, 2004 Share Posted February 14, 2004 Hello Friends, I'm the proud owner of a 1994 SC400 and new to the forum. The top part of the ignition key recently broke off so that I can no longer carry the key on a keyring. The key and unlocking button still work fine. The Lexus dealer tells me that a replacement key would run about $330. They suggested that perhaps I drill a hole in the top of the key which seems fairly drastic. I thought perhaps I could simply purchase one of those colored covers for the top of the key but I can't find one that will fit. Any suggestions? Thanks for your help. Quote Link to comment Share on other sites More sharing options...
joedoc Posted February 14, 2004 Share Posted February 14, 2004 a key is 330.00? i assume that is the key with the button you use for remote unlocking? why don't you just use the smaller key without the remote button? Quote Link to comment Share on other sites More sharing options...
born2ron Posted February 14, 2004 Author Share Posted February 14, 2004 Thanks for the response. Yes, the key that's broken is the one that has the button to unlock the doors. The smaller key that I'm using doesn't have that button which isn't that big of a hassle but it's apparenty the valet key which also will not unlock the trunk. So everytime I want to get into the trunk, I have to open the door and use the remote trunk release. I believe that the reason that the replacement key is so expensive is because they also have to replace the computer chip or whatever is inside the key to open the door. Apparently, I can't just go down to the local locksmith to have a duplicate key made. Quote Link to comment Share on other sites More sharing options...
joedoc Posted February 14, 2004 Share Posted February 14, 2004 there is a full sized key (not the valet key) that opens everything but doesn't have the remote locking electronics. that is the one i always use since it is much less bulky. tell the dealer or locksmith that you just want a copy of the key without all the electronics. hopefully that will save you about 325.00 Quote Link to comment Share on other sites More sharing options...
rabidus Posted February 14, 2004 Share Posted February 14, 2004 I just bought a key from the dealer, it doesn't have the remote, it works for everything, and it cost $55, they cut it off of the VIN and it works fine... The person that I bought the car from only had the one remote key... I think the remote key is only around $125... Try another dealer, I think that one is trying to rip you off!!! Anthony Quote Link to comment Share on other sites More sharing options...
