When I start my sc300 1996 the belt squills just at start up,just a chirp! then if I turn on the
ac and turn the wheels all the way to bind the belt it does it worst, I can drive it
and it does ok. I even pulled off the belt and replaced it and no change,But while
I had the belt off the pullys on power steering and ac turns freely. even the ten.pully
so any help please?
I have been told try changing the belt tensioner?
It just seems like if I crank it with ac on it really squills when the belt is under
the most load, As said above with ac off it still makes noise but just a churp then
no more unless the ac is on and turning and gasing on it a little.If I turn on the ac as I'm moving
it does fine it seems like the belt is just slipping for whatever reason...
  • 1 month later...
more than likely it sounds like your car's way of telling you 'Im old my bones creek' dab your finger in some motor oil and grease the tensioner a little stay away from that alternator with that stuff though it will stop working if to much foreign substance gets in
