The latch on the left side of my 2002 LS's coin tray is broken. Suggestions for repair and/or replace, please. Is this a relatively easy R&R?
Am I correct in assuming tht the 2 small bolts beneath it which are exposed when the emergency brake release handle is pulled out are the bolts holding the try in place? I have the base Millennium Silver with the grey ahd white interior.
This is a dual post on the other Lexus Forum.
Thanks,
!Removed!
Hi,
Unless you can find a used one the whole assembly is $154.99 from Lexus Part # 55450-50060 A0 ( AO is Ivory color)
You are correct in that the 2 screws release the coin tray.
