frantastic Posted August 14, 2010 Posted August 14, 2010 My window on my 1993 SC400 on the passenger side will roll down, but will not roll up. I purchased another window switch and installed it but its doing the same thing. So i purchase a window regulator to install, but i can't completely remove the door panel. I am stuck at the inner door release handle, can someone tell me how to get that pryed apart without damaging anything?
intakerGS Posted August 14, 2010 Posted August 14, 2010 I'm not sure if this goes for your car, but with a gs300, you can remove the inside handle bezel cover (pry it open with a screwdriver). Under it is a screw.
OGY Posted September 1, 2010 Posted September 1, 2010 My window on my 1993 SC400 on the passenger side will roll down, but will not roll up. I purchased another window switch and installed it but its doing the same thing. So i purchase a window regulator to install, but i can't completely remove the door panel. I am stuck at the inner door release handle, can someone tell me how to get that pryed apart without damaging anything? There should be like 9 bolts that hold your door in place. One located at the tweeter (Remove the cover) 3 underneath, two at the hand rest, two in the front, and one at the actual door handle itself. It is only a plastic cover that you need to pry out. A skinny screwdriver should do the trick.
sc400InTraining Posted October 26, 2010 Posted October 26, 2010 The best thing to do for the sake of your car would be to deliver 12 volts to window motor to roll it up, This is how I get my window up and down for the time being(3 months and still no resolve to permenantly fix) Ill post how to do this with pictures step by step when I feel like it.
