caji Posted August 11, 2010 Share Posted August 11, 2010 Hi Guys, I have a 94 ES300 that is leaking oil on the passenger side of the engine. No leaks on the oil drain plug, oil filter, and the valve cover. Before I power wash the underside of the engine, are there any thoughts about where the oil leak might be? Hope to hear from you guys. Quote Link to comment Share on other sites More sharing options...
caji Posted September 5, 2010 Author Share Posted September 5, 2010 I found the oil leak. It's coming from the power steering high pressure hose. The cost to replace it, around $150 parts and labor. So guys if you have a small drops of oil from the passenger side inspect the power stirring high and low pressure hoses. Quote Link to comment Share on other sites More sharing options...
dcfish Posted September 5, 2010 Share Posted September 5, 2010 Thanks for the heads up Quote Link to comment Share on other sites More sharing options...
