iral Posted July 25, 2010 Share Posted July 25, 2010 check engine came on, went to reset & abs started blinking vsc came on. removed scanner - check engine went off abs went off vsc went off. then vsc came on and later check engine came on. Is this a vacuum problem? Quote Link to comment Share on other sites More sharing options...
billydpowell Posted July 25, 2010 Share Posted July 25, 2010 on my 99LS, my CEL & VSC came on and my code was P1349. OIL CONTROL VALVE DIRTY. cleaned, no more problem. about 30 minutes work. ocv.pdf Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted July 25, 2010 Share Posted July 25, 2010 Many issues can cause these warning lights. Did you read a code with your scanner? The last time these warning lights happened on my 00 LS it was a bad TPS but other issues can cause the same warning lights. Quote Link to comment Share on other sites More sharing options...
dasha1 Posted August 6, 2010 Share Posted August 6, 2010 check engine came on, went to reset & abs started blinking vsc came on. removed scanner - check engine went off abs went off vsc went off. then vsc came on and later check engine came on. Is this a vacuum problem? The VSC and ABS lights started to go on in my 98 when I went over bumps and would then go out after a few minutes. The remote lock would also not work until the headlights turned off. It turned out to be the battery. A new battery solved both problems. The old battery was only about seven months old, bought from Autozone. Quote Link to comment Share on other sites More sharing options...
