Bru2You Posted July 18, 2010 Share Posted July 18, 2010 Just bought my first Lexus. ES300. Nice car, rides like a dream. Bought it used from a dealer and received a 60 warranty. The AC seems a bit strange at idle and I'm not sure if it is normal for this car. At first the AC would blow hot at idle. Increase the revs at all and the cold kicked right on. Brought it in and they replaced the freon and pressure checked it. It's better now but still "clicks" on and off at low idle which also shows up on the tach(bounces). It seems if the idle was just a touch higher this wouldn't happen. The mechanic says its cycling when it clicks. I am very mechanical and have worked on cars my whole life but this is way more modern than I am used to. It idles at about 500, which seems very low. Quote Link to comment Share on other sites More sharing options...
mxl4729 Posted July 20, 2010 Share Posted July 20, 2010 anything and everything u ever wanted to know about AC and fixing AC http://www.volkspage.net/technik/manuaisecatalogos/01/AutomotiveHeatingandAirConditioning.pdf Quote Link to comment Share on other sites More sharing options...
mrringtone Posted July 29, 2010 Share Posted July 29, 2010 You might want to clean your throttle body. I have a 2002 ES 300 and I had the same issue and if you ignore the issue your car would not turn over one day and it will drain your battery. Its the best fix for this issue, You can also have your AC check for Free at local shops if they offer it and throttle body cleaner is very cheap just go to any auto parts store and your all set. Quote Link to comment Share on other sites More sharing options...
SAMATSAAB Posted August 24, 2010 Share Posted August 24, 2010 The car should idle between 675-725 rpm with ac on at idle. 500 rpm is too low. Check your throttle body and make sure it is not coated with carbon buildup, and check for any vacuum leaks. Quote Link to comment Share on other sites More sharing options...
Beasley RB Posted August 28, 2010 Share Posted August 28, 2010 Just bought my first Lexus. ES300. Nice car, rides like a dream. Bought it used from a dealer and received a 60 warranty. The AC seems a bit strange at idle and I'm not sure if it is normal for this car. At first the AC would blow hot at idle. Increase the revs at all and the cold kicked right on. Brought it in and they replaced the freon and pressure checked it. It's better now but still "clicks" on and off at low idle which also shows up on the tach(bounces). It seems if the idle was just a touch higher this wouldn't happen. The mechanic says its cycling when it clicks. I am very mechanical and have worked on cars my whole life but this is way more modern than I am used to. It idles at about 500, which seems very low. My car does this after the battery has been disconnected and the computer needs to reset. (I mean it does EXACTLY as you described) After a couple of days of driving it settles down and runs fine. The computer has to learn your driving habits. If nothing else is wrong in a few days, say 5, you will notice it runs fine. Mine idles smoothly at 500 rpm. When all the clicking stuff is going on it idles at less than 500 RPM. Always has and runs like a champ. Good Luck. Quote Link to comment Share on other sites More sharing options...
