Tranny Fluid Change
kuziwk
so i changed the fluid,pulled off the pan cleaned it nice and changed the filter. I added two litres of oil, the tranny shifts very smooth. After taking it for a drive i checked the level again which used to be good but is now showing no oil while its running not even in the cold??? there are no leaks as i checked it over. Also on Lexs tutorial site it said the drain and refill amount is 1.9 litres?
Just add some more fluid until you get the correct level; more than 1.9 litres could have drained out.
