Low Beams Won't Turn On
2003 ES 300 - Both low beam headlights (std halogen) stay off when the headlight switch is in the ON (top) position.
The headlight icon appears on the instrument panel & the high beams work when the headlight switch is moved.
DRL and all other headlight switch related lights work fine. Fuses are OK.
Help, we have a trip planned for next week, and the warrantee just ran out.
I did notice that u said fuse are fine in your post, however describe fine. Is the fuse getting electricity, check that with a meter. other than that, there isn't really much you can do other than maybe buying one new bulb and testing it and see if it works. If it doesn't probably means that your connectors/fuse are bad. If it works just means your low beam light bulbs are out. Shouldn't be that expensive and hard to fix. You can usually grab a bulb on ebay for a cheap price.
