lex460 Posted June 5, 2010 Share Posted June 5, 2010 [No Laminate windows just triangle fix. Listen to attached file. VOC002.mp3 Quote Link to comment Share on other sites More sharing options...
slam_w2k Posted September 21, 2010 Share Posted September 21, 2010 I am surprise noone else reply to this post. So is what I hear is with the wind noise or NO wind noise. My deal did the glass and trim fix, but I still hear wind. I went back in and they replaced both the triangles and my car sound just what I hear on the mp3. So it the noise normal? Quote Link to comment Share on other sites More sharing options...
Jeff in TX Posted September 21, 2010 Share Posted September 21, 2010 I think you are wanting us to tell you that you don't have the infamous wind noise problem. That's pretty hard to do. I think the better answer is: What do you think? Do you think you have a wind noise problem? The cars are so exceptionally quiet when they don't have the wind noise problem that no reasonable person would think there is a problem when there isn't a problem. So, if you are unsure then it is likely that your car has a problem. The trim must be repaired carefully, in a very conservative manner to attain the sensation of total isolation from outside noises. A very conservative trim repair method that has yielded superior results for many DIYers is detailed at: http://www.clublexus.com/forums/ls460-ls460l-and-ls600h/506217-instructions-for-the-jmcraney-wind-noise-fix.html Quote Link to comment Share on other sites More sharing options...
