tonytoca Posted May 31, 2010 Share Posted May 31, 2010 I have a 1998 GS400. I have determined that the alternator is bad. I jacked up my car and removed the bottom alternator bolt and the top nut. When I try to slide the alternator off, it is clearly hitting the power steering pump pulley. Is this normal or do I have to take the pulley off or did I miss a step? I still have the top wire (terminal B) and rear plug connected as it is in an awkward position and it does not seem to be stopping me from pulling the alternator. Has anyone ever removed the alternator without removing the power steering pump pulley? The whole reason I have to replace the alternator because of a leak from the power steering pump. Quote Link to comment Share on other sites More sharing options...
intakerGS Posted May 31, 2010 Share Posted May 31, 2010 You need to take the PS pump pulley off. Quote Link to comment Share on other sites More sharing options...
tonytoca Posted May 31, 2010 Author Share Posted May 31, 2010 Thanks for the info. Does anyone have step-by-step instructions for replace and removal of the alternator and PS Pump. I forsee that once I get the alternator off that I will have tackle the PS pump to find out where the leak is coming from. Quote Link to comment Share on other sites More sharing options...
intakerGS Posted May 31, 2010 Share Posted May 31, 2010 Perhaps this can be of use: Quote Link to comment Share on other sites More sharing options...
drew028 Posted August 1, 2010 Share Posted August 1, 2010 Once you get it loose you can maneuver it around and drop it from the bottom. Just becarful of your trans lines. Quote Link to comment Share on other sites More sharing options...
Lexus323 Posted November 8, 2019 Share Posted November 8, 2019 You can double nut top bolt.This makin u able tp remove stud allowing atl.to drop put bottom.Without removing power steering pully. Quote Link to comment Share on other sites More sharing options...
Jherm918 Posted February 24, 2021 Share Posted February 24, 2021 Lexus323 what do you mean by double nut the top bolt. Do I put the regular nut finger tight then put another nut behind it and crank the bolt off using the first nut. The second nut will stop the first nut from turning off wont it. Quote Link to comment Share on other sites More sharing options...
