IRVSMITTY Posted February 5, 2004 Posted February 5, 2004 I HAVE A 91 LS400.ABOUT 5 YEARS AGO MY YELLOW FOG LIGHTS STOPPED WORKING.I TRIED TO FIX THEM MYSELF,BUT NO LUCK.ABOUT 3 WEEKS AGO I TRIED TO TURN ON MY HEADLIGHTS AND LO AND BEHOLD THE FOG LAMPS CAME ON.BUT THE COST WAS I DIDN'T HAVE ANY HEADLIGHTS.THATS UNTIL I PUSHED OUT ON THE HANDLE THAT CONTROLS LOWBEAM AND HIGHBEAM.WHEN I PUSHED OUT ON THE HANDLE AS IF TO CUT ON MY HIGHBEAMS THE LOWBEAM LIGHTS CAME ON.AND WHEN I PULL THE HANDLE BACK IN FOR LOWBEAMS JUST THE YELLOW FOG LAMPS COME ON.IS THIS A SWITCH PROBLEM?IF SO WHATS THE BEST WAY TO GET A REPLACEMENT ONE?
VMF Posted February 6, 2004 Posted February 6, 2004 i cant really understand what you are trying to stay. first of all please dont type in caps since it means screaming and second please be more specific about the problem you have since its really hard to understand the sequence of your actions
90LS400Lexus Posted February 6, 2004 Posted February 6, 2004 Sounds like your headlight switch is bad. I would try locating one at a local salvage lot. Or call your Lexus dealer. They should not cost more than $100 or so. Perhaps more. Parts for these cars can be very expensive.
UCF3 Posted February 6, 2004 Posted February 6, 2004 It sounds like a wiring problem, as if you didn't connect the right wire to the right circuit or your high beam wire is loose. I would suggest getting a wiring harness diagram from lexus; you might have to pay for it. Otherwise, you could try getting a new harness, from a salvage yard, or one of the aftermarket retailers or tunershops.
IRVSMITTY Posted February 6, 2004 Author Posted February 6, 2004 Thanks for the info. guys. I will try and locate a light switch. p.s. This is a great forum to get educated guys. I'm proud to become a member.
SKperformance Posted February 7, 2004 Posted February 7, 2004 it is more than liekly the headlight switch since it can cut the fog lights off when the high beams are turned on i would say it is miss aligned rather than buying a new peice i would try and clean or adjust it to make the contacts again it may have been a bad arc removing some of the contact and the carbon finally wearing away to get covered up again
