Larry ES Posted May 24, 2010 Posted May 24, 2010 Hi, does anyone knows how to take the glove box door out? If anyone has the service manual please let me know the step by step instructions... Thanks, Larry
mhawkin1 Posted May 25, 2010 Posted May 25, 2010 "Take the glove box door out" ?? What does that even mean?
ketch Posted May 26, 2010 Posted May 26, 2010 "Take the glove box door out" ?? What does that even mean? Larry, are you looking for instructions on replacing the cabin filter? If so, I can tell what the '10 ES manual says, but it doesn't require that the glove box door come off. There is a small cover over the filter in the back of the glove box that must be removed from inside the glove box, and that will get you access to the filter. Hope this helps.
Jim13 Posted May 28, 2010 Posted May 28, 2010 Hi, does anyone knows how to take the glove box door out? If anyone has the service manual please let me know the step by step instructions... Thanks, Larry Yes. If you are talking about the directions to "Remove the glove box cover" for accessing the cabin air filter, the owners manual has a pretty good picture of what you need to do (page 311 in the one from 2007). You basically slide the plastic panel up to get it to disengage from the slot and then remove it.
