cm786 Posted May 5, 2010 Posted May 5, 2010 While using synthetic oil, how often (miles) do you change oil in a 2008 LS460?
SW03ES Posted May 6, 2010 Posted May 6, 2010 Doesn't Lexus specify 10,000 miles now with synthetic oil? Do you have the factory maintenance schedule?
limocad Posted May 18, 2010 Posted May 18, 2010 It may only be the 2010 then... No. The 2010 requires oil change at 5K too and it uses 0W20 which is 100% synthetic. After 10K miles I switched to 5W20, Mobil 1. The car is running smoother and quieter with 5W20.
lex460 Posted May 18, 2010 Posted May 18, 2010 It may only be the 2010 then... No. The 2010 requires oil change at 5K too and it uses 0W20 which is 100% synthetic. After 10K miles I switched to 5W20, Mobil 1. The car is running smoother and quieter with 5W20. I noticed the same thing less chain noise with Mobil 1 5-20w full syn over the Toyota red.
