meadow Posted April 18, 2010 Share Posted April 18, 2010 How too replace high mounted stoplight - 1998 ES300 1. Slide the cover straight forward (toward you) to release the latches - they are two latches at rear of the cover); I used two screwdrivers, one at each side, to pull the cover forward out. 2. Lift cover up 3. Twist out (counter clockwise) bulb socket - same bulb type as tail stoplight 4. Push the socket back in - align one larger slot to push the socket back in Quote Link to comment Share on other sites More sharing options...
whw Posted April 19, 2010 Share Posted April 19, 2010 There haven't been too many recent posts on 98 ES problems. I noticed yours on the high-mounted stoplight and I wanted to see if you have experienced problems with hestitation and jerkiness at 40-45 mph while at cruise speed (not acelerating or decelerating). This started on mine at about 210,000 miles. I have 217,000 on it now. My mechanic said he can't find the reason. There were no codes and no lights. Any thoughts? Quote Link to comment Share on other sites More sharing options...
Sexus ES300 Posted April 19, 2010 Share Posted April 19, 2010 you might want to start a new thread for that problem. but is it only 45mph and above? Try using injector cleaner or cleaning out the MAF Quote Link to comment Share on other sites More sharing options...
