yank30265 Posted April 3, 2010 Share Posted April 3, 2010 how do I replace the bulb in the 3rd brakelight(highmount). Alldata says to remove the subwoofer tray but dosent tell u how. I dont have a speaker in there but i need to get inside to get the bulb. I also found two brown wires going to the speaker area that were cut any idea where they go? Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted April 3, 2010 Share Posted April 3, 2010 I had a 90 LS for over 13 years and replaced the high mounted stop light bulbs a couple of times. If I remember correctly all you have to do is pry up the front edge of the speaker cover/light assembly and the whole thing will pop out. Flip it over to change the bulb. Reinstall by snapping the assembly back down. Quote Link to comment Share on other sites More sharing options...
VBdenny Posted April 4, 2010 Share Posted April 4, 2010 As far as I know, mine has the original bulb. I think I have only had a couple bulbs go out ever but the one that was the worst was the fog light bulb. $30 special order from dealer, nobody else had it. Quote Link to comment Share on other sites More sharing options...
RDM Posted April 5, 2010 Share Posted April 5, 2010 I had a 90 LS for over 13 years and replaced the high mounted stop light bulbs a couple of times. If I remember correctly all you have to do is pry up the front edge of the speaker cover/light assembly and the whole thing will pop out. Flip it over to change the bulb. Reinstall by snapping the assembly back down. What he said. Pry up and slide forward. 10 seconds. Quote Link to comment Share on other sites More sharing options...
