Chrisgo Posted March 30, 2010 Share Posted March 30, 2010 My son had a carfull of kids and after they left the front passenger seat would not go back. All other functions worked except going back. After 2 hours of playing with it and since it was all the way forward you could not get to the 2 bolts. So we finally figured out that there are 4 bolts that hold the seat to the frame, loosen them, slide the seat back and then got to the front two bolts. Could not find any loose wires and so we started manually turning the shaft and the seat came back. Then we noticed that on the front of the seat were two phillips screws that hold a plastic shield that covered the shafts the turns and moves the seat up and back. A socket set with a 12mm socket and an extension was all we need to manually get the seat back off the dash. At least it is back to a comfortable position and in my free time I can read more about what to check next. Quote Link to comment Share on other sites More sharing options...
Sexus ES300 Posted March 30, 2010 Share Posted March 30, 2010 similar problem with my passenger seat, the actual seat part not the back is tilted backwards and wont come back up. So your kinda wedged in the seat all the other functions work fine though. If you find a fix let me know Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted March 31, 2010 Share Posted March 31, 2010 My son had a carfull of kids and after they left the front passenger seat would not go back. All other functions worked except going back. After 2 hours of playing with it and since it was all the way forward you could not get to the 2 bolts. So we finally figured out that there are 4 bolts that hold the seat to the frame, loosen them, slide the seat back and then got to the front two bolts. Could not find any loose wires and so we started manually turning the shaft and the seat came back. Then we noticed that on the front of the seat were two phillips screws that hold a plastic shield that covered the shafts the turns and moves the seat up and back. A socket set with a 12mm socket and an extension was all we need to manually get the seat back off the dash. At least it is back to a comfortable position and in my free time I can read more about what to check next. Once you manually moved the seat back, see if it will move forward with the switch. If so the switch is bad. The seat has 4 dc motors, the switches that control these motors are double pole, double throw, center off. If the motor moves in one direction, but not the other, the the control switch is normally the problem. If you own a digital volt meter, you could measure the voltage to the switch. If not, if it moves in one direction and not the other, you have a bad switch. Quote Link to comment Share on other sites More sharing options...
Chrisgo Posted March 31, 2010 Author Share Posted March 31, 2010 My son had a carfull of kids and after they left the front passenger seat would not go back. All other functions worked except going back. After 2 hours of playing with it and since it was all the way forward you could not get to the 2 bolts. So we finally figured out that there are 4 bolts that hold the seat to the frame, loosen them, slide the seat back and then got to the front two bolts. Could not find any loose wires and so we started manually turning the shaft and the seat came back. Then we noticed that on the front of the seat were two phillips screws that hold a plastic shield that covered the shafts the turns and moves the seat up and back. A socket set with a 12mm socket and an extension was all we need to manually get the seat back off the dash. At least it is back to a comfortable position and in my free time I can read more about what to check next. Once you manually moved the seat back, see if it will move forward with the switch. If so the switch is bad. The seat has 4 dc motors, the switches that control these motors are double pole, double throw, center off. If the motor moves in one direction, but not the other, the the control switch is normally the problem. If you own a digital volt meter, you could measure the voltage to the switch. If not, if it moves in one direction and not the other, you have a bad switch. Quote Link to comment Share on other sites More sharing options...
Chrisgo Posted March 31, 2010 Author Share Posted March 31, 2010 can you order just the switch? If yes, how hard is it to get the switch out to replace it. The seat does go forward no problem. Thanks for the input. Chris Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted March 31, 2010 Share Posted March 31, 2010 You may be able to the switch apart and clean it, if not try ebay, or your local wrecking yard for a switch Quote Link to comment Share on other sites More sharing options...
