How Can I Turn Off The Steering Wheel Adjustment?
david1walker
I have a 98 and the owners manual has no mention of being able to turn it off.
The "Auto tilt away" function of the steering wheel on a 98-00 LS400 can be turned on/off with a Lexus Diagnostic Tester and appropriate program card. A number of other functions are customizable.
My 94 has a switch just below the turn signal that will turn it off.
And your point would be .... ?
1994 was the last model year with the on/off button so your information is not going to help the OP with his 95 LS400.
Right, no way to disable that feature on the 95. It bugged me too when I first got my 95, learned to live with it though.
If it doesn't go to the previous spot, push the appropriate memory button on the door before shifting into gear to coax the steering wheel to the right position. Mine does this too from time to time. I believe it has something to do with a sensor in the ignition switch.
