3rd Brake Light Removal
jasperaxle
Im trying to remove my 3rd brake light to install an XM antenna. Has anyone removed one before? I don't want to damage it by removing it wrong. This is a 2005 LS430 Thanks
On my 97 you just push the front in and it hings up. If it is pretty easy to do like this, then yours in different and you need to wait for another response. Hope this help!?
I'd like to hear how you are running the wire. I had mine done at best buy.
I will give it a try, I ran the xm wire under the door sills and then under the back seat on the side and tucked it in between the back window and the back window deck. I now need to just get it in the third brake light.
Some people use velcro tape and leave the sat antenna exposed on the rear window shelf -- might work for you if your sat antenna looks decent.
