Power Steering Flush Photos And Brief Description
K9crew
No one carries that stuff around here ;)
Have you done any research who supplies toyota with their oil?
99, the Toyota part# for Toyota Auto Trans Fluid (Dexron II & III approved) is 00718-ATF00.
Any Toyota dealer can order it from their local regional Toyota distribution center.
No I don't know who make genuine Toyota lubes and fluids. I do know they are
not merely rebottled and relabeled existing over the counter products. Alot
of people can't believe this. Like on another forum one guy said he had
done alot of research and found out genuine Toyota Motor 5W-30 oil was merely
rebottled Chevron 5W-30 oil. But as you can see http://www.saber.net/~monarch/chevron2.jpg they don't even look the same so it's highly unlikely they are chemically identical.
Then on another forum some guys got together and sent in virgin samples of all kinds of different antifreezes to Titan Labs in Denver for chemical analysis. The analysis came back and showed the chemical composition of Toyota Long Life Coolant was far different than any other popular antifreezes.
So the Toyota engineers do the research and come up with the specs for their own fluids and lubes and then contract US companies to formulate them.
a quick story about the sensitivity of changing fluids in a vehicle.
i have a honda crv and rather than go to the dealer for the transmission
fluid change, i went to a fast-oil change service and they said they could
do the transmission change but had to add an additive to make the fluid
they added match the honda standard. so some few weeks later while driving on the hwy and letting up on the gas i kept getting this weird
grinding noise which was driving me nuts.. thought tran was going out.
i rememberd the fluid change at the " fast- rip- off place", took it back and asked if they ever had probs like mine in the past and they said
never. i went to honda and got five qts of their fluid and, changed out
and the noise dissappeared immediately. moral..yes p/s pumps, transmissions, hydraulic fan pumps, engin, etc., all have their limits as to how far you can stray from the recommended additive.
re p/s fluid replacement. it cant any any simplier than this:
i just finished replacing the seal/o-rings in my p/s pump and wanted to do a complete fluid purge of the system. you can do this w/o removing
any parts like the coolant tank or whatever.
bought 1 gal of dex III. disconnected the suction line from the resevoir
to pump and forced a 5/8", 8' piece of discarded garden hose over the
rubber suction hose. found the biggest a**ed funnel i had and wrapped
some electrical tape around the spout to make a tight fit when wedged
into the resevoir. poured about a qt into the funnel and put discharge
line into gal jug... this setup makes it easy for one person.
started car with steering wheel level and let run for about 5 sec and cut
motor to check how much was pulled out of funnel. after doing this and
a few times with the wheels turned full left and right you get a feel for
how long you can run engine before depleting funnel contents. ran the whole gal thru and fluid was clean at the end and all air was purged.
in no time at all i had the system purged and the pump was running as
smooth as a baby's a**.
Monarch - thanks for the info! ( you must be a scientist or something :lol: )
Lexie,
About the Honda - yes, they do make a specific trans fluid! Most Dex III ATF are labelled and Exclude Honda on their list ;) Honda's are a little particular.........
On the PS flush -
I wanted to attach a tall, clearish, plastic pitcher ( holding a quart or two) that would attach to the reservoir and seal tightly (like the cap). This would have been much more efficient than just filling the reservoir alone and having to "bump" starter and refill so many times.......Then I could just watch the fluid level slowly fall down until it got to reservoir level and turn off motor!!
I didn't think the funnel/tape would create such a good seal! That's great :lol:
Did it "seep" at all around the reservoir? Run down the side? Anythng?
I didn't want to take a chance on losing 1/2+ quarts all over the engine compartment :unsure:
I'll try this (or similar) next flush - Thanks!!
99
i mistakenly said i hooked up the garden hose to the suction hose but
i meant to say to the rubber part of the return hose. the nipple where
the return hose goes was plugged off.
re leakage:
none at all. i just pressed and twisted the funnel into the resevoir and
the tape seated in nicely.
yes i agree, a clear plastic container mounted atop the reservoir would
certainly make this a cake walk. be nice if you could find one that held
a couple of qts or more. i have some clear jugs that i get drinking water
in (zephyrhills spring water, 1 gallon cap). i will cut a hole in the bottom
and see if i can come up with some kind of simple seal that will mate
the jug top to the reservoir since i plan to flush one more time soon.
lexie
lexie,
yea, if we could come up with a device that would "lock" like the cap we'd be in business!!!
99
ps - I used clear 3/8" I.D. hose and used a brass male coupling to attach with the return hose - no leaks and I was pleased :D
I just tried and couldn't get it either.......
Fortunately I saved it on a MS word file :lol:
I 've tried to attach several times....there's something slow & quirky with the servers....
PM me and I'll send the file to your email if you want!
99
  • 3 months later...
