CVN86 Posted March 22, 2010 Share Posted March 22, 2010 Hey everyone, I've recently been having some problems with my transmission. Once I start the car and put it into drive, the transmission would hesitate and the gears would not shift smoothly. The car would jerk a few times until I actually let go of the gas. The car would shift smoothly after this has happened. There has been no problem with shifting when stopping at stop lights and accelerating. This problem usually occurs each time I first start the car. The car had absolutely no other issues other than this and I was wondering what could probably be causing this to happen? Any help would be much appreciated. Thanks guys. Quote Link to comment Share on other sites More sharing options...
igbeserk Posted March 22, 2010 Share Posted March 22, 2010 so you're having shifting issues when you shift to D and when you start driving like picking up speed? it jerks a bit? if that's the case it sounds like your front motor mount might be bad. Those are the symptoms i have had with my 95 es300. When you're parked and shift to D and it jerks badly then yea thats most likely your motor mount. if you put it in R and it does the same thing then your rear motor mount could be bad also. I would say get those checked out. mainly the front though since you're driving forward more than reversing. If not your motor mount then it could be the first gear in your tranny i believe, but i'm not expert. I hope this helps. Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted March 23, 2010 Share Posted March 23, 2010 Have you checked the check the trans oil level? What is the color of the oil, and does it smell burnt? See if there are any stored codes that may indicate what the problem might be Quote Link to comment Share on other sites More sharing options...
