obaida Posted March 18, 2010 Share Posted March 18, 2010 I am having RX330 2004, after changing oil I drive my car for 15 min then when I stopped my car VSC,Break, and ABS light came on. i switch the engine OFF and start it again all lights went to the normal condition (OFF). This problem rise again after 2 days and I follow the same procedure to make the light off. advice please!!! Quote Link to comment Share on other sites More sharing options...
RX in NC Posted March 18, 2010 Share Posted March 18, 2010 First thing I would do is to read the OBDII codes that have been thrown. Could very well be a faulty speed sensor. Get your codes read first, though.... Quote Link to comment Share on other sites More sharing options...
code58 Posted March 19, 2010 Share Posted March 19, 2010 If it didn't do it before you changed oil and did it after, look for things that you may have dislodged in changing the oil or filter. Did you do anything with the air filter box? There is a hose on the back of it that comes off when the box is moved and is often not reinstalled and it sets some codes, don't remember which ones. I'm betting there's a good chance that something got disturbed when changing the oil. Take a good look. Quote Link to comment Share on other sites More sharing options...
obaida Posted March 20, 2010 Author Share Posted March 20, 2010 If it didn't do it before you changed oil and did it after, look for things that you may have dislodged in changing the oil or filter. Did you do anything with the air filter box? There is a hose on the back of it that comes off when the box is moved and is often not reinstalled and it sets some codes, don't remember which ones. I'm betting there's a good chance that something got disturbed when changing the oil. Take a good look. Thanks, i checked the air filter and i found taht the air box not fixed in proper way. Quote Link to comment Share on other sites More sharing options...
