1998 Gs400 Repair Manual
I purchased an on-line repair manual for a 2002 GS-300 about 5 years ago. It came as several .pdf files and each one was not labeled as to contents, so you had to go through each one to see what subject was covered. Also seems like it is not a complete manual, since many areas of the car are not covered such as certain body parts, even typical maintenance items like changing the plugs! I should have gone through it when I first bought it, then I could have pursued it with the seller. Now, however, I forget who I got it from ! Just be sure when you buy a .pdf manual on line to check it and make sure it is complete, covering everything in the vehicle. I miss my old Chilton manual on my 1971 Camaro. It had detailed instructions and explanations for every part of the car. Where is this type of repair manual for the Lexus????
