Had my transmission oil and filter changed last week and recently took it on the highway. I noticed that I was pumping out about 3000 rpms at 70 mph. I don't recall the engine reving that high at that speed before. Anybody know why new fluid would keep the OD from working properly?
how do you knwo the o/d is not working
does the rpms change easily with the gas pedal?
you may not have reconnected the wire that goes over the filter properly or not filled it with enough fluid causing it to not engage properly
  • 7 months later...
