fay31 Posted February 9, 2010 Share Posted February 9, 2010 Does anyone have any insight on how to remove the driver's side interior door panel? I believe the power door lock actuator is either failing or needs to be lubricated. FA Quote Link to comment Share on other sites More sharing options...
xxstewart Posted February 9, 2010 Share Posted February 9, 2010 Here's the service manual content on the front door. I've never disassembled the door, and take no responsibility for any broken parts or fingers. Good luck. GX470_Door.pdf Quote Link to comment Share on other sites More sharing options...
fay31 Posted March 2, 2010 Author Share Posted March 2, 2010 Here's the service manual content on the front door. I've never disassembled the door, and take no responsibility for any broken parts or fingers. Good luck. Thank you!!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
Pillardman Posted May 15, 2011 Share Posted May 15, 2011 Here's the service manual content on the front door. I've never disassembled the door, and take no responsibility for any broken parts or fingers. Good luck. Thanks for posting this! It was very helpful. Quote Link to comment Share on other sites More sharing options...
daveflpe Posted May 18, 2011 Share Posted May 18, 2011 how do you remove the door panel if you can not get the door open? My lock is stuck in the locked position.... Quote Link to comment Share on other sites More sharing options...
xxstewart Posted June 11, 2011 Share Posted June 11, 2011 how do you remove the door panel if you can not get the door open? My lock is stuck in the locked position.... You might try stopping at a local police station or towing service, and ask if they can "slim-jim" the door. This is how locked doors can be unlocked -- maybe they can spring the release mechanism also. Quote Link to comment Share on other sites More sharing options...
LZMF1 Posted July 2, 2011 Share Posted July 2, 2011 Here's the service manual content on the front door. I've never disassembled the door, and take no responsibility for any broken parts or fingers. Good luck. you wouldn't happen to have the manual content for the rear doors would you? i'm basically having the same problem the OP has but with the back door on the drivers side. i ordered the lock assembly and it's being delivered today. removing the panel is no problem there are only 3 hidden screws and a bunch of clips holding it in place but removing and replacing the lock assembly seems to be a wee bit more involved. i did a dry run yesterday and couldn't for the life of me figure out how to remove the assembly. i got the 3 torx screws out no prob but removing the actual assembly from the door was impossible without taking further actions which i have no clue what those actions are. Quote Link to comment Share on other sites More sharing options...
LZMF1 Posted July 5, 2011 Share Posted July 5, 2011 OK kids i have an update! i ordered the part from sewell lexus and had them fedex 2 day it for $190 i decided to give it another dry run since the part has not been delivered yet. i took the door panel off, removed the 3 torx screws from the lock assembly, disconnected all the electronics+lock and handle wires from the door, removed the panel, and loosened the 2 10mm screws that hold the track for the window. with the track loose i wiggled the lock assembly out. i disassembled the lock assembly and found that the contacts for the little motor that locks and unlocks the door were crusted up and filthy i cleaned them, reassmbled the lock assembly and put the door back together and it works! i guess i have to decline the delivery when it gets here. i just saved myself $190 for the part. my dealership wanted $240 for the part and @$250 for the install. Quote Link to comment Share on other sites More sharing options...
LZMF1 Posted July 31, 2011 Share Posted July 31, 2011 my fix was temporary and started to fail again. luckily i had the lock assembly that i had ordered. i replaced it and everything works Quote Link to comment Share on other sites More sharing options...
Fayer Posted August 16, 2011 Share Posted August 16, 2011 Does anyone have any insight on how to remove the driver's side interior door panel? I believe the power door lock actuator is either failing or needs to be lubricated. FA Thank you paste a link, this is very useful to me! Thank you again for sharing! Quote Link to comment Share on other sites More sharing options...
srknight1 Posted August 17, 2011 Share Posted August 17, 2011 Hi Guys. I am a rookie to this site ,but i need help in removing the right side door panel to replace the mirror . An *BLEEP* stole the r/s cover and broke the the mirror assembly. Dam those dealers are not cheep!!!. I paid $ 513.00 for a new one without the glass.. Love my 04 Ls430 and just want to save $$ by doing it my self. Where and how do I start to remove the door panel. Is there a video on this anywhere? And what tools do I need. Any help would be appreciated.. Please step by step instruction for me please . Thanks Quote Link to comment Share on other sites More sharing options...
LZMF1 Posted September 20, 2011 Share Posted September 20, 2011 Hi Guys. I am a rookie to this site ,but i need help in removing the right side door panel to replace the mirror . An *BLEEP* stole the r/s cover and broke the the mirror assembly. Dam those dealers are not cheep!!!. I paid $ 513.00 for a new one without the glass.. Love my 04 Ls430 and just want to save $ by doing it my self. Where and how do I start to remove the door panel. Is there a video on this anywhere? And what tools do I need. Any help would be appreciated.. Please step by step instruction for me please . Thanks all you really need to remove the door panel is a philips head screw driver. when it comes to removing the actual mirror assembly you'll need some torx drivers and i cannot recall the exact size. check your PMs i sent you a message. Quote Link to comment Share on other sites More sharing options...
mstar Posted September 21, 2011 Share Posted September 21, 2011 Here's the service manual content on the front door. I've never disassembled the door, and take no responsibility for any broken parts or fingers. Good luck. Is there any chance you have access to the same service manual information for a 2004 RX330. I need to replace the driver side mirror assembly. Thank you Quote Link to comment Share on other sites More sharing options...
stephon123 Posted October 20, 2011 Share Posted October 20, 2011 Here's the service manual content on the front door. I've never disassembled the door, and take no responsibility for any broken parts or fingers. Good luck. Thanks for posting service manual, it helped me a lot Quote Link to comment Share on other sites More sharing options...
bigrvol Posted September 10, 2012 Share Posted September 10, 2012 Thanks for the PDF Quote Link to comment Share on other sites More sharing options...
