retdep Posted February 8, 2010 Share Posted February 8, 2010 I have a 2000 ES with 105,000 miles. the fuel pressure damper was leaking and i replaced it about 3,000 miles ago The damper started leaking today. Any thoughts of what could cause this as im 800 miles from home and dont want stuck. Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted February 8, 2010 Share Posted February 8, 2010 Are there any other symptoms? Was the damper replaced with a used or new unit? Is it leaking from the fittings? or the body of the damper? Unless the fuel pressure was too high, it is hard to see many other things that would cause a repeated leak. And if the pressure was too high, you should see other symptoms. Quote Link to comment Share on other sites More sharing options...
gordonw Posted February 8, 2010 Share Posted February 8, 2010 Did you replace the two gaskets along with the damper? Quote Link to comment Share on other sites More sharing options...
retdep Posted February 9, 2010 Author Share Posted February 9, 2010 Did you replace the two gaskets along with the damper? The damper was new as were the gaskets. It is leaking from the damper not the fitting. Quote Link to comment Share on other sites More sharing options...
