kenmac Posted February 7, 2010 Share Posted February 7, 2010 Does anyone know if you can replace the bulbs in the electric window switches as mine are really dull, and also the rear fog light switch is this illuminated as mine works fine but the headlight adjuster is lit up but not the fog light switch. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted February 7, 2010 Share Posted February 7, 2010 Does anyone know if you can replace the bulbs in the electric window switches as mine are really dull, and also the rear fog light switch is this illuminated as mine works fine but the headlight adjuster is lit up but not the fog light switch. The backlights on the window switches of my 00 LS400 are not very bright either. It would have been nice if the light intensity was adjusted up and down with the rheostat switch with all the dash lights. I think the lights in the window switches are diodes -- never heard of anyone replacing them. I doubt if many on this North American part of Lexus Owners Club is going to know anything about your headlight beam adjuster dial or the rear fog light switch next to it -- Lexus cars sold in North America didn't have manual beam adjusters or rear foglights. I wouldn't know about this stuff either if I hadn't had Lexus LS400 owning co-workers in the UK and Europe. I'm guessing that your rear foglight switch would be easy enough to pop out of the dash so you can have a looksee -- might require removing the trim panel under the dash. Quote Link to comment Share on other sites More sharing options...
kenmac Posted February 7, 2010 Author Share Posted February 7, 2010 Cheers Jim, yeah meant to delete the part about the fog light but forgot Quote Link to comment Share on other sites More sharing options...
ravig292 Posted February 9, 2010 Share Posted February 9, 2010 i wanted to that to mine too but the lights are diodes that are soldered to the chip. you can change them but, if you mess up you can damage the chip and would end up buying a new one. Quote Link to comment Share on other sites More sharing options...
RDM Posted February 9, 2010 Share Posted February 9, 2010 A good bit of the switches in the dash/console are lit with bulbs, I found out after replacing the shift level indicator on mine. I ordered the bulbs for the transmission select and ride height switches by the lever and the heated seats and traction control switches above the ashtray. They weren't cheap though. The window switches though as said are not replaceable easily, you could do a solder in job though with LEDs, there's a lot of stuff online about people converting their entire dash cluster and switch arrays to LEDs. Pretty cool if you have the patience for tedious work. Quote Link to comment Share on other sites More sharing options...
