waltermelon Posted February 2, 2010 Posted February 2, 2010 Just come back from maintenance services at a Lexus dealership. There is no car wash this time, given the reason that the cold weather (<10 degree C) might lock the brake. I know that they are using touch-less automatic car wash. Is it unsafe to go through automatic car wash under extreme cold weather? Thanks!
ESpecial Posted February 2, 2010 Posted February 2, 2010 Just come back from maintenance services at a Lexus dealership. There is no car wash this time, given the reason that the cold weather (<10 degree C) might lock the brake.I know that they are using touch-less automatic car wash. Is it unsafe to go through automatic car wash under extreme cold weather? Thanks! Maybe -20 C is extremely cold, but surely not <10C. My car would never get washed if 10C was the cutoff point. Water doesn't even freeze at that temp. Never had a problem with brakes freezing. You use them almost immediately after a wash when you drive off and the heat dries them out.
lemon Posted February 16, 2010 Posted February 16, 2010 They're probably talking about the parking brake. If water gets in the cables/mechanism, it can freeze (regular brakes have heat build up as you use them, which usually dries out the brakes.
