eds92sc Posted February 2, 2010 Posted February 2, 2010 Hello everyone, Still in the process of troubleshooting the intermittent no start and stall problem on my 92SC400. My mechanic was finally able to duplicate the problem, but no codes. Once, it happened at idle while moving forward at less than 5mph. The second time, it was on an onramp when it stalled. The eng won't restart now. It may or may not be the ECM according to my mechanic, still checking wires, grounds, etc. Where is the ecm exactly? I'm planning on purchasing one off the junkyards for 135 bucks. Hopefully the ECM I buy won't be bad itself and cause new problems.
SeanGrac Posted February 2, 2010 Posted February 2, 2010 Hello everyone,Still in the process of troubleshooting the intermittent no start and stall problem on my 92SC400. My mechanic was finally able to duplicate the problem, but no codes. Once, it happened at idle while moving forward at less than 5mph. The second time, it was on an onramp when it stalled. The eng won't restart now. It may or may not be the ECM according to my mechanic, still checking wires, grounds, etc. Where is the ecm exactly? I'm planning on purchasing one off the junkyards for 135 bucks. Hopefully the ECM I buy won't be bad itself and cause new problems. front passenger floorboard
eds92sc Posted February 3, 2010 Author Posted February 3, 2010 Hello everyone,Still in the process of troubleshooting the intermittent no start and stall problem on my 92SC400. My mechanic was finally able to duplicate the problem, but no codes. Once, it happened at idle while moving forward at less than 5mph. The second time, it was on an onramp when it stalled. The eng won't restart now. It may or may not be the ECM according to my mechanic, still checking wires, grounds, etc. Where is the ecm exactly? I'm planning on purchasing one off the junkyards for 135 bucks. Hopefully the ECM I buy won't be bad itself and cause new problems. front passenger floorboard Thanks Sean, You da man.
