omega6485 Posted January 16, 2010 Posted January 16, 2010 just bought a 1992 sc400. just wondering what all should be the first mods. other than the morn like intake/exhaust and things. looking for like "secret" mods.
dcfish Posted January 16, 2010 Posted January 16, 2010 High stall torque converter, Full tune up, Clean the throttle body, And as mentioned intake and exhaust. If you wanted a monster then you should have went with the 300 and do a turbo swap.
omega6485 Posted January 16, 2010 Author Posted January 16, 2010 High stall torque converter, Full tune up, Clean the throttle body, And as mentioned intake and exhaust. If you wanted a monster then you should have went with the 300 and do a turbo swap. thanks man. just got rid of my ls1. on it, i did a tb bypass of the coolant. havent looked on this one though but does this motor have coolant running through the tb?
dcfish Posted January 16, 2010 Posted January 16, 2010 High stall torque converter, Full tune up, Clean the throttle body, And as mentioned intake and exhaust. If you wanted a monster then you should have went with the 300 and do a turbo swap. thanks man. just got rid of my ls1. on it, i did a tb bypass of the coolant. havent looked on this one though but does this motor have coolant running through the tb? Nope, No coolant through the TB ;)
omega6485 Posted January 16, 2010 Author Posted January 16, 2010 High stall torque converter, Full tune up, Clean the throttle body, And as mentioned intake and exhaust. If you wanted a monster then you should have went with the 300 and do a turbo swap. thanks man. just got rid of my ls1. on it, i did a tb bypass of the coolant. havent looked on this one though but does this motor have coolant running through the tb? Nope, No coolant through the TB ;) ok thanks man
