MBman Posted November 24, 2009 Share Posted November 24, 2009 For no reason that I can tell the light goes on , I check the pressures, all good, reset it , seems OK for now, any ideas why it might have gone on? What is the values (pSI) it actually responds to? Quote Link to comment Share on other sites More sharing options...
pauljcl Posted November 24, 2009 Share Posted November 24, 2009 For no reason that I can tell the light goes on , I check the pressures, all good, reset it , seems OK for now, any ideas why it might have gone on? What is the values (pSI) it actually responds to? I have an 09RX350. The maunal implies that he reset sets the warning to trigger at or slightly below the psi at which the ties are at when the reset is initiated. Have you checked your spare? Quote Link to comment Share on other sites More sharing options...
BambooMait Posted November 24, 2009 Share Posted November 24, 2009 For no reason that I can tell the light goes on , I check the pressures, all good, reset it , seems OK for now, any ideas why it might have gone on? What is the values (pSI) it actually responds to? It's almost always the spare ...and sometimes spare really needs to be inflated much higher than the recommended psi's of the other 4 tires.... Quote Link to comment Share on other sites More sharing options...
MBman Posted November 24, 2009 Author Share Posted November 24, 2009 thanks everyone, aired up the spare , reset the light, seems to be all well right now, Quote Link to comment Share on other sites More sharing options...
