camlex Posted November 23, 2009 Posted November 23, 2009 Hello, Dealer using Denso SK20R11 asking for $12.00 each Orailly NGK IFR6T11 same as came on car IFR6A11 (Confirm with NGK) asking for $7.00 each. Both plugs Iridiums. Please share your input. Thanks in advance
George_Jetson Posted November 23, 2009 Posted November 23, 2009 That is a very subjective question. You will get a dozen different opinions, of which some will be valid. I would use NGK, I have used then plenty of times before without a problem. Whichever you use, gap them before installing. I would also use a very small amount of anti sieze compond on the threads. Make sure that it is a small amount because contaminates burning in the cylinders can damage the cat's.
eatingupblacktop Posted November 23, 2009 Posted November 23, 2009 Not sure about the NGK's, but the Denso's come pre-gapped. Also check your HT wires.
camlex Posted November 23, 2009 Author Posted November 23, 2009 Thanks george, NGK requested not to use anti sieze compond do you know the Gap
George_Jetson Posted November 24, 2009 Posted November 24, 2009 1.1 mm to 1.3 max. Even when they say that it is pre-gapped, it never hurts to verify. I personally put a Very light coat of anti-sieze on it, just enough to color a little over half the threads ( the half oposite the electrode). I have been worked on a lot of pre-cat engines, which I gave a reasonable coat. Since cats came out, I use much less. I have worked on engines where pulling the plug was very difficult due to corrosion, hence I always put a little bit on the threads. There are different views on this, so you will need to pick which you feel comfortable with.
camlex Posted November 24, 2009 Author Posted November 24, 2009 I looked NGK site, asking for 0.044, when I checked a gap at orailly, was showing 0.4 Can somebody verify NGK is original plug comes with new cars? http://www.ngksparkplugs.com/part_finder/c...ngineid=1464793 OE Laser iridium selling for $7.00 each vs Denso http://www.toyodiy.com/parts/p_U_2000_LEXU...TPGKA_1901.html SK20R11 with VVT-I Toyota can sell me this for $8.60 each Believe me, i am not after money saving, Rear is hard and i don't want to do again. Thanks, Thanks,
George_Jetson Posted November 24, 2009 Posted November 24, 2009 alldata shows either ND SK20R11 or NGK IFR6A11 with a gap of 1.1 mm (.04 in) you should be fine with either plug.
camlex Posted November 24, 2009 Author Posted November 24, 2009 Thank you george. Have a safe and Happy Thanksgiving. Take care.
George_Jetson Posted November 24, 2009 Posted November 24, 2009 You're welcome, hope the plug swap goes well. If you find that the outside of the plugs are oilly, I would stop. That would indicate that the valve cover tube seals are leaking. And you will need to consider replacing the valve cover gaskets.
camlex Posted November 26, 2009 Author Posted November 26, 2009 You're welcome, hope the plug swap goes well. If you find that the outside of the plugs are oilly, I would stop. That would indicate that the valve cover tube seals are leaking. And you will need to consider replacing the valve cover gaskets. It's done. Rear were little hard. I used two 3" extensions. I have to do little engineering on plug socket. i opened front first to learn. 5/8" plug socket has little rubber piece which hold plug while you pulling up. It was too tight so after screw plug in, extension was loosing its grip. i took rubber piece out and fix it where not hold plug too tight. Front took me 10 minits where rear took 50 minit. I did go with Denso Iridium 120K miles spark plug from toyota. Charge me $8.50 each. No oil were found on plugs. good news. Again, thank you for all help. Now, I am ready for Thanksgiving Dinner...
