What Can I Do?
stein
You have not stated the mileage, but I would suggest checking the airfilter, and under the rad cap (look inside to evalute the visual condition of anti-freeze). On some cars that have spotty service, it will be evident when you remove the cap. Also check for stickers on the windshield. If everything looks normal, I would do the next recomended service, and check condition of brake pads. When you remove the wheels to check the pads, give a good visual of the suspension. A lot of things like torn, worn rubber bushings will be evident. Check rubber brake lines, they should look dusty gray color. If the lines look dark (especially near the ends) they should be replaced.
If you are just stating out with servicing you car, I STRONGLY recomend a good set of jackstands, or ramps. The jack that comes with the car should never be trusted for anything. Never put yourself in a position where any part of you could be caught underneath the car when it drops. Always keep yourself clear of the car when it is on any type of jack. It must be on a jackstand or good set of ramps before working underneath a car.
i just bought an es300 and was wondering what some of the easiest things to do first to it to make it better since im still in highschool?
ENJOY IT! I have a 92, Black with Tan interior.. I gave it a good scrub down inside and out... Its Lexus, So I kept mine Classy! Best of Luck
sorry george its a 93 es300 with 102k on it i bought it with 97k i want her to last me a long time.i did the rear brakes im going to the do the front brakes very soon.what simple things can i do??im not that mechanically inclined but with some help i can do most stuff.thanxx
I would suggest pruchasing a Hayes, or Chilton manaul, You can order one from any decent auto part store. They are written so that beginners can understand them and they have good ilistrations in them. They go into good detail, unlike the factory manuals that have very little explainations and would be of little use for a person that wants to learn. It takes time, but once you understand how the different parts interact it will seem much more clear to you.
