GS300dude Posted November 22, 2009 Posted November 22, 2009 okay a few months ago VSC, ABS, VSC OFF lights came on my 99 Lexus GS300...... I really didnt care about it since the car was functioning normal....but recently i saw a video on how VSC works and considering the way i drive...i really need that VSC to be working properly....also VSC works with ABS....so i checked out the ABS code and it says passenger side sensor...so yesterday i ordered a OEM ABS SPEED SENSOR.. total $187.00........ so im thinking if i replace the sensor that should turn off the the ABS along with the VSC light.. since the VSC works ABS ..according to the video i saw..... so im hoping the lights will go off.....
Patrice Posted December 6, 2009 Posted December 6, 2009 okay a few months ago VSC, ABS, VSC OFF lights came on my 99 Lexus GS300...... I really didnt care about it since the car was functioning normal....but recently i saw a video on how VSC works and considering the way i drive...i really need that VSC to be working properly....also VSC works with ABS....so i checked out the ABS code and it says passenger side sensor...so yesterday i ordered a OEM ABS SPEED SENSOR.. total $187.00........ so im thinking if i replace the sensor that should turn off the the ABS along with the VSC light.. since the VSC works ABS ..according to the video i saw..... so im hoping the lights will go off..... did it help when you bought the OEM ABS SPEED SENSOR did the 3 lights go off
dcfish Posted December 6, 2009 Posted December 6, 2009 okay a few months ago VSC, ABS, VSC OFF lights came on my 99 Lexus GS300...... I really didnt care about it since the car was functioning normal....but recently i saw a video on how VSC works and considering the way i drive...i really need that VSC to be working properly....also VSC works with ABS....so i checked out the ABS code and it says passenger side sensor...so yesterday i ordered a OEM ABS SPEED SENSOR.. total $187.00........ so im thinking if i replace the sensor that should turn off the the ABS along with the VSC light.. since the VSC works ABS ..according to the video i saw..... so im hoping the lights will go off..... did it help when you bought the OEM ABS SPEED SENSOR did the 3 lights go off The car has been totaled :o
GS300dude Posted December 13, 2009 Author Posted December 13, 2009 okay a few months ago VSC, ABS, VSC OFF lights came on my 99 Lexus GS300...... I really didnt care about it since the car was functioning normal....but recently i saw a video on how VSC works and considering the way i drive...i really need that VSC to be working properly....also VSC works with ABS....so i checked out the ABS code and it says passenger side sensor...so yesterday i ordered a OEM ABS SPEED SENSOR.. total $187.00........ so im thinking if i replace the sensor that should turn off the the ABS along with the VSC light.. since the VSC works ABS ..according to the video i saw..... so im hoping the lights will go off..... did it help when you bought the OEM ABS SPEED SENSOR did the 3 lights go off The car has been totaled :o yes unfortunately, and that darn company is having hard time giving me refund, its amazing how they quickly take your money......
Mr. GS Posted February 4, 2010 Posted February 4, 2010 okay a few months ago VSC, ABS, VSC OFF lights came on my 99 Lexus GS300...... I really didnt care about it since the car was functioning normal....but recently i saw a video on how VSC works and considering the way i drive...i really need that VSC to be working properly....also VSC works with ABS....so i checked out the ABS code and it says passenger side sensor...so yesterday i ordered a OEM ABS SPEED SENSOR.. total $187.00........ so im thinking if i replace the sensor that should turn off the the ABS along with the VSC light.. since the VSC works ABS ..according to the video i saw..... so im hoping the lights will go off..... Hey I have a question. When you encountered this issue was there beeping noise along with the abs, brake, and vsc lights being on. I'm having this issue but I can't figure this out. When it comes on my brakes fail (wont start). This morning I drove it failing then the lights cut off and everything was fine. Can you please help me. Redwar2477@yahoo.com!!!!!!!!!
maniaco02 Posted March 12, 2010 Posted March 12, 2010 Hello everyone, this is my first post. I also own a 98 GS300 since November and I encountered that Issue 3 times already. Living In canada and getting pretty cold weather, one morning I got stuck in snow and gave a bit too much on the gas pedal. That was the first time these Lights came on, I also noticed that the VSC control really got off since I could drift in the road pretty easily. It reseted after I got the motor to off for a good time, couple of hours. Hapenned to me 2 others times, when I tried to accelerate really fast from a stop. I went to the deal and talked with some mecanicians. One of them had already seen this problem 2 times he said. He says it's probably the abs pump in the main abs control computer (if I can say so) that is getting aged and tired. However this cannot just be changed, it requires the change the whole module, which is around 3000$ CAN. To myself, this looks like a good explanation to my problem, would make sense since it happens when I ask a lot of power to the car. I hope this helped you, if however it happened in the same circomstance as I had. Sorry for my bad english. Good Luck !
